Orbi WiFi 7 RBE973
Reply
Netgear D7000 - lost connection
Gerhard_Öfi
Hello,
i use Netgear D7000 with A1 Telekom Austria provider since several month without problem but
since June the connection breakes about 2 times a week. In that case only a reboot/restart of the router solves this problem.
I can't find any problem in administration protokoll file but this file seems to be written new every router restart. I can't connect to the router with LAN if this problem happens so i can't check problem based of actual logfile. The LED's do not show problem... A reboot with iOS does not work.
Details:
- latest Firmware V1.0.1.48_1.0.1)
- Internet-Dienstanbieter Adam (Österreich)
- Transfermodus: VDSL(PTM)
- DSL Modus (VDLS2)
- Kapselung (PPPoE (PPP over Ethernet)
- Verbindungsmodus (Dauerverbindung)
- DNS-Server (from Provider)
- WAN (Automatically)
The ISP said that the telefon line does not have a problem.
Any ideas?
Thanks for feedback/help and best regards,
Gerhard
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 4
Gerhard_Öfi
Betreff: Netgear D7000 - lost connection
Any help/idea?
Message 2 of 4
antinode
Guru
> Any help/idea?
   Not really, but...
   V1.0.1.50_1.0.1 exists now.  The Release Notes file says only:
      New Features and Enhancements:
      o Security Enhancement.
so I wouldn't expect much.
      http://netgear.com/support/product/D7000.aspx
Message 3 of 4
Gerhard_Öfi
i have already installed latest updates. After 3 days connections brokes without information again :(....
For further analyse i need to know how i can save logfile permanantly - at the moment after restart a new logifile will be created and so i have no way no analyse furhter....
regards
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3898 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
