Orbi WiFi 7 RBE973
Reply
NightHawk X4S D7800 won't allow me to edit schedules to turn wifi on and off since new firmware upgr
BrydG
Hi,
Just downloaded and installed the latest firmware upgrade and since then I have been having problems with the wifi scheduler. I like to turn the wifi off and then have it start ack up at a certain time and I could do this with the previous firmware but for some reason the buttons on the schedule page which allow you to add to time schedule and edit those times etc are there but not active. I am not sure what has changed since, can anyone help please?
And the time zone allows me to choose a different time zone but keeps showing as 1 Jan 1970 and then the time is a few hours out of sync with current time
Message 1 of 3
Retired_Member
Not applicable
Re: NightHawk X4S D7800 won't allow me to edit schedules to turn wifi on and off since new firmware
did you try a factory reset?
Message 2 of 3
BrydG
Hi, Yes I did...originally downloaded the new firmware update over the wifi which may have mucked things up, but then I did a factory reset with ethernet cable.
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 1434 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
