- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk D7000 2.4Ghz WiFi issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk D7000 2.4Ghz WiFi issues
- Mark as New
- Bookmark
- Subscribe
- Permalink
It says Channel Auto (3)
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have had problems since christmas, but things have improved.z
at christmas, 2.5GHz became very flaky and all android devices had trouble connecting on 2.5GHz. i enabled the 2.5GHz. my Moto G Play phone still cannot connect but other android devices can. my phone it gets stuck with 'Authenticating'. i have tried deleting the connection on the phone and redefining. no good. it is on the latest google play services.
the guest network is still working perfectly and my phone is the only one to have problems. i'm just going to leave the guest network on until i get another phone. (fwiw, this phone does not have 5GHz.)
i noticed this discussion about channels... i have the router set to Auto and it was using channel 3. in this discussion i see the suggestion that that cannot happen. i set to channel 1, rebooted... still on 1. i set back to auto, rebooted, now on 2.
there is not much in the way of other networks around here. usually i see just one other network, and that is currently using channels 1,6,11. so it makes sense to me that the router has chosen something other than 1,6,11.
- Mark as New
- Bookmark
- Subscribe
- Permalink
well the article was interesting.
but i can't see that i need to do anything. my router automatically chose channel 2, even though 'Auto' is set and 'Enable 20/40 MHz coexistence' is selected.
currently my wifi analyser shows no other networks. (fwiw, my android phone still has an authentication problem even when there is no other network)
lots of other notes in this thread say select 'Auto' and 'Enable 20/40 MHz coexistence'. i have done that. i don't notice any performance problems. why should i care?
- Mark as New
- Bookmark
- Subscribe
- Permalink
i changed the setting to channel 3, rebooted. i had channel 3 but the wifi analyser showed 20MHz. i changed to auto and rebooted.... and was back at channel 2.
i'm not going to fight this. life is too short. and only one device is using this network. all the others are using 5GHz.
fwiw, the Moto G Play is a slow phone... i doubt that i'd notice any difference no matter what the speed.
thanks for the help and patience.
- Mark as New
- Bookmark
- Subscribe
- Permalink
As show in attached file, my router have 190 hours of uptime.
The WiFi interfaces have 75 hours uf uptime because I changed the channels.
For these reasons, I think that the issue is resolved.
No drop out of any device un 2,4GHz band.
On 2,4GHz I have the following devices:
A Chromecast;
3 webcams;
a couple of Android smartphone.
Hope that all of you have the same situations.
A couple of mounth are long time to resolve an issue.
But at the end, the trouble are fixed.
Have a good life!
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@Tomhurstwrote:
Trouble isn't fixed! I'm still rebooting 1-2 times a day
Readed your previous posts.
When I had the issue, I could reach my router through ethernet.
I think that your trouble have a different origin.
Do you still can't connect to router through ethernet during the 2,4GHz fall down?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Basically the whole router is dying 1-2 times a day now!
- Mark as New
- Bookmark
- Subscribe
- Permalink
As @IT9MBZ suggests, looks like you have a different issue.
Is your D7000 still in warranty? If so, I'd start the returns process.
If you are looking for further guidance here, if you haven't done that already you might do better to start a new discussion that gets you away from the long running 2.4 GHz problem. That's only part of your problem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I'd have a go at starting a new conversatioin. This one started in November and ran out of steam when Netgear delivered new firmware and Google fixed Chromecast.
By all means mention the 2.4 GHz thing, but make it clear that it isn't the Chromecast bug that has hit you, more a total meltdown of the D7000.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@IT9MBZ
wrote:As show in attached file, my router have 190 hours of uptime.
For these reasons, I think that the issue is resolved.No drop out of any device un 2,4GHz band.
A Chromecast;
3 webcams;
Have a good life!
I, too, have had a successful run with V64. I have two Chromecasts, one Google Home Mini and an android phone. All the Google devices now have the latest preview FW/Software.
The D7000 V1 has had no dropouts or authentication errors in second test period from 10:50 on 10 Feb 2018 giving 15 days successful running (first test period 10 days 10 hours also with no dropouts or authentication errors). So in total that is nearly a month trouble free.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RME9632 wrote:
596 posts and no one have notice tha all the problems of this unit the 2.4ghz the dropouts the crashes all are related to OVERHEATING.
Would that it were that simple.
There was one report elsewhere about a completely different device, where someone found that it was unwise to put it on a carpet. But for most people overheating had nothing to do with the problems they experienced. It was down to Chromecast and Android for a lot of people.
Glad it worked out for you, but I would still ensure that your D7000 is up to date with the latest firmware. That is what fixed many of these problems.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@RME9632wrote:
596 posts and no one have notice tha all the problems of this unit the 2.4ghz the dropouts the crashes all are related to OVERHEATING. To all of you out there try this, raise the unit about 1 or 2 inches from the ground with some feets and try again. Mine is running about 9 days like this and works flawless. I had all of these problems before that trick with the feets
You are incorrect, overheating was brought up multiple times in this thread, tested and while some found it helped their router it wasn't the general cause of the 2.4Ghz issues. The primary reason (but not the only reason) for specific 2.4Ghz dropouts was Android devices hammering the router with traffic and like many on this thread, the issues stopped the moment Google patched their devices.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've been running firmware version V1.0.1.60_1.0.1 since it came out. I haven't any of the WiFi networks drop out in well over a month or more now.
There were two other changes in the house as well, one Galaxy Note 4 was switched to an iPhone X and I replaced my S7 with an S9. In case anyone cares or, thinks it matters
- Mark as New
- Bookmark
- Subscribe
- Permalink
I've had this problem since mid-2017. Never figured it out... I've been limping through by using my other wifi router (which also sucks), and rebooting the D7000 every few days or switching to the opposite band when needed. I was hoping to wait until the 802.11ax routers were available, but I don't know if I can wait any more.
This is my first Netgear product. Are they all this bad? If I buy a replacement router now, it won't be a Netgear, but I don't know if I should avoid their stuff forever, or just this model...?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Are you serious? I thought it was pretty obvious... but if you must, Purpose #1 of my post was to add another voice to the growing chorus of people with similar problems, hoping that Netgear (or another community member) might have a suggestion on how to fix it. Purpose #2 was to ask, as I did (which you can see from the use of "question marks"), if problems like this were common to all Netgear products, or if it was just this model.
Since you asked, what is the purpose of YOUR post, which asked the purpose of mine?
- Mark as New
- Bookmark
- Subscribe
- Permalink
People usually turn up here seeking help and advice. But it isn't always clear what they are asking, if anything.
When a message lacks any obvious question that the volunteers who try to provide that help and advice can follow up, the natural response is to see it the person who posted the message wants help and to clarify their question.
Now that you have made it clear that your visit was intended to add to the list of aggrieved users, we can safely move on to other topics.
Remember, this place is all about problems. People who have no issues simply won't turn up here. The best selling hardware will naturally evoke more queries.
You will see the same pattern on all support sites.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, thanks for trying to help. These are the devices connected.
2 amazon fire TVs, Chromecast, Chromecast Audio, Google home, PS4, Smart Plug, 3 Windows PCs, Printer, 3 smart lights, and 4 Android phones.
I also have a Netgear wifi extender but I don't have that connected at the moment since it doesn't work very well. It's way too slow.
Not sure how accurate those statistics are because I just had to reset the router because the internet just stopped working randomly (again).
- Mark as New
- Bookmark
- Subscribe
- Permalink
It would be nice if everyone who posts here on the D7000 blog would indicate what firmware release they are on and what ISP they are connected to. Would makes this blog it a little more comprehensive.
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
