Orbi WiFi 7 RBE973
Reply
Nighthawk D7000 - DHCP Address Reservation not Working
jaseuk
Tutor
Hi,
I purchased a Nighthawk D7000 AC1900 a few weeks ago in order to replace by BT Home Hub 5 which I use with BT Infinity 1. A few days ago I decided to attempt to reserve a number of IP addresses as I need this in order for Port Forwarding to work correctly however no matter how many times I tried it woudnt work. I am not sure if this was affected by the new firmware or not.
Is this something anyone else has experienced?
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 106
Accepted Solutions
jaseuk
Tutor
Re: Nighthawk D7000 - DHCP Address Reservation not Working
Well I ended up reverting back to the 1.0.0.32 firmware and guess what it works perfectly.
Message 5 of 106
All Replies
clithes
Prodigy
Nope everything working fine on latest firmware.
I would suggest not using Internet Explorer when changing your settings as for some reason this never works well with Netgear GUIs
http://www.downloads.netgear.com/files/GDC/D7000/D7000_UM_EN.pdf - Page 209
Hope this helps
Modem: Vigor 130 | Routers: R7800, R8500 & R9000 | ISP : Plusnet Unlimited Fibre Extra
Powerline: PLP1200x4 PL1200x6 | WiFi Extenders: PLW1000 & XWN5001
Switches: GS105Ex2, GS105Ev2, GS108Ev2, GS305
Message 2 of 106
jaseuk
Tutor
thank you for the prompt reply clithes. I was using Firefox when I attempted to set the reserved ip addresses but I will give it another go.
I will also take a look at the link you posted.
I'll report back good or bad 😉
thanks
Message 3 of 106
jaseuk
Tutor
I have tried and tried but it just wont work properly. I even re-installed the latest firmware. I have managed to allocate one device a reserve ip address but anything else and it wont work for me. I am doing all this on a firefox browser.
Any ideas?
Message 4 of 106
jaseuk
Tutor
Message 5 of 106
David-
I have the same issue. I set up address reservations under 10.0.0.32, and they continued to work under 10.0.0.34. However, I reset to factory settings to attempt to fix a different issue, and was unable to get IP reservations to work.
So if you update back to 10.0.0.34 your current settings will stick. Probably not worth it though. 🙂
Message 6 of 106
GTunney
Apprentice
I'm having the same issue after upgrading to 1.0.0.34
I had numerous reservations for all my devices and it's been running fine on 1.0.0.32, updated to 1.0.0.34 and now all my devices have started getting DHCP leased IPs.
Message 7 of 106
jaseuk
Tutor
I opened a ticket with Netgear and made them aware of this issue. I also pointed them in the direction of this thread. Might be worth you guys doing the same.
Message 8 of 106
GTunney
Apprentice
Thanks Jase, I've since downgraded the firmware and voila! All my DHCP reservations back in play.
Message 9 of 106
jaseuk
Tutor
Excellent news. I am still assisting Netgear support with the issue so hopefully I can report back soon.
Message 10 of 106
furyau
Exactly the same problem.
I am downgrading however I really wanted the fix for the downstream interrupted when upload is maxed out.
Hopefully they can release a .36 version soon with the issue resolved.
Message 11 of 106
jaseuk
Tutor
Netgear have acknowledged a problem with the 1.0.0.34 FW and have removed it from their servers. They are working on a fix I am told.
Message 12 of 106
furyau
Good, cause I logged a ticket with Netgear and it was just immediately closed. Twice. No response apart from you are outside your 90day support window.
Pretty poor from one of their top of the line products. I can definitely say that we will not be using the D7000 for any clients....and I recommend steer clear of it, this model has been nothing but trouble.
Message 13 of 106
Sm0t
Oh good, glad I'm not the only one. I was going crazy trying to figure out what I was doing wrong!
How do I roll back to .32?
Message 14 of 106
GTunney
Apprentice
Just install over the top of .34
Message 15 of 106
Gi0
Is .38 working fine for you guys?
Just installed it over .34 and after the reboot i am still getting DHCP leased IPs for the devices i have reserved IPs for.
Message 16 of 106
GTunney
Apprentice
I've not got .34 I'm still on .32 for the mo, will try upgrading once I'm home.
Message 17 of 106
Gi0
Please let us know how it goes when you do.
Cheers!
Message 18 of 106
clithes
Prodigy
I've also had to revert back to version 1.0.0.32 as version 1.0.0.38 is not using reserved IP addresses as detailed above
Message 19 of 106
Gi0
Thank you for the feedback. I'm going back to .32 as well since as it seems the problem has not been fixed *again*. And it's really disappointing.
Message 20 of 106
Gi0
More feeback from me: Went back to .32, everything works as it should.
Message 21 of 106
GTunney
Apprentice
Can't believe they still haven't resolved the DHCP issue.
I'll be sticking with .32 for the moment.
Message 22 of 106
BMG
Hi,
I also just purchase a new nighthawk D7000 3 days ago to replace a Billion 7800VDOX that was failing, upgarded the firmware to .38 and I cannot get DHCP reservations to work.  It's been driving me crazy.  Thanks for the firmware tips.  I'll downgrade to .32 of the firmware and advise.
Cheers.
Message 23 of 106
BMG
And with the downgrade of firmware from .38 to .32 DHCP address reservation is working again so I'll stick to version .32 of  the firmware.
Thanks
Message 24 of 106
Nrg91
Unbelievable that after 2 firmware version, the dhcp reservations still do not work
I went back to .32
Wake Up Netgear!!!
Message 25 of 106
Discussion stats
Announcements
Orbi WiFi 7
