- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
- « Previous
- Next »
Nighthawk D7000 - DHCP Address Reservation not Working
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk D7000 - DHCP Address Reservation not Working
I've just re-applied .44 over the top of .44 already installed which keeps settings and this has resolved the issue.
Very very stange range as I tested on my laptop and that was getting 70, looks like all devices are now getting the full 70 to them.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Good feedback. Yet more evidence that it sometimes helps to do a factory reset after flashing the firmware.
It doesn't always work to reload the save settings, but once again you've provided useful information on when it can work.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P- Mark as New
- Bookmark
- Subscribe
- Permalink
The only thing I noted with .44 is that I had to change my OpenVPN config on my client to the new one off the router - I'd not had to do that with the last couple of updates. Other than that OK so far - might double check the WiFi given other comments.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I just bought one and am trying to install, but with problems in DHCP reservation..
My firmware says 1.0.7.2_1.1.93
It also says GUI language version 1.0.7.2_2.1.38.2
Is this the bad version 38? Why do the numbers look so different?
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jpullam wrote:I just bought one and am trying to install, but with problems in DHCP reservation..
This thread is for the D7000, that firmware version is for the R7000.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Sorry I didnt appreciate the difference in model number.
In case anyone finds this, I rolled the software back to 1.5, did a factory reset and then an ipconfig /release on my desktop and it started working.
- « Previous
- Next »
