- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk D7000 Heatsink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk D7000 Heatsink
Hello saturn5
Do you have the router in a open area with nothing stacked on top of it?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Darren, I have recently bought to thermal adhesive pad and have bonded a heatsink to the broadcom chip. I have the router on it's side witht it's lid off and a 92mm fan blowing across the heatsink. The router now seems to be stable but it's early days. The chip has never really got too hot to touch but heat is the only thing I can think thats making the router freeze up intermittently. Not enough info on the web regarding this model - yet!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello saturn5
If your modem is getting to hot I would suggest contacting support if the modem is still under warranty.
https://www.netgear.com/support/contact.aspx?cid=wmt_netgear_organic
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi, Netgear support are of little use. As mentioned, I believe a heatsink is missing from my router for some reason. If you read here: "http://forum.kitz.co.uk/index.php/topic,15601.30.html" it mentions a heatsink for the D7000. I will carry on with my trials, I have ordered a cheap netbook cooler to sit the router on, this combined with the heatsink I have fitted should do the trick. Regards
- Mark as New
- Bookmark
- Subscribe
- Permalink
You can see internal pictures of everything from FCC filings
https://apps.fcc.gov/eas/GetApplicationAttachment.html?id=2624594
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi Richud, thanks for the reply, unfortunately I cannot open the link for some reason. Maybe you could screen grab and post a pic of the mysterious heatsink?
Thanks.
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have been running router on netbook cooler for a while now, seems better bit still failed under heavy load on Xmas day.
