- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Nighthawk D7800 AC2600 NBN with FTTC
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have the exact same issue as this thread
Netgear Nighthawk Router D7800 - NBN configuration
I'm with the same ISP (iinet) and my line is also FTTC.
If the moderator had answered the question I wouldn't be creating this new thread.
Yes, other people have made posts about configuring NBN with this device. I haven't found one that is about FTTC connections (except for the above link, where the question was dismissed).
Could someone PLEASE provide instruction as to how to set up this modem/router to work with FTTC NBN.
Every bit of advice from Netgear for NBN is in relation to FTTP, FFTH, FTTN or FTTB.
FTTC isn't mentioned once in this link:
https://kb.netgear.com/30439/What-is-an-NBN-network-and-is-my-NETGEAR-DSL-modem-router-compatible
I'm sure if this issue is addressed, this thread will be instructive/helpful to future users like myself that have been wracking their brains trying to get their FTTC NBN to work with a Nighthawk D7800.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Nighthawk D7800 AC2600 NBN with FTTC
- Mark as New
- Bookmark
- Subscribe
- Permalink
ignore what the ISP says, It's really easy to configure Nighthawk routers with NBN FTTC, just plug the supplied ethernet cable into the FTTC NBN NCD (aka Modem) Ethernet port and from there into the WAN port on your Nighthawk.
In the Nighthawk setup, manually configure your internet config and at the top of the page where it says "Does your Internet connection require a login?", select "No" and leave everything else as "Get from ISP", then Apply the settings.
Wait a couple of mins for the Nighthawk to connect and voila, the Internet is all your.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Please look at these setting int eh image
There was a very samll settin change I had to make but can remember what is was so follow all the settings int eh image
- Mark as New
- Bookmark
- Subscribe
- Permalink
No one dismissed your question. But you clearly dismissed the answer. That just told you where to look for answers and that you had put your message in the wrong place.
Let's get back to basics.
The D7800 is a DSL modem/router. FTTC in Oz is not DSL.
The problem with the label FTTC is that it means different things in different places. In the UK it means "fibre to the cabinet", the green box up the street. In Oz it is Fibre to the Curb, which may or may not be the same thing.
Don't take my word for it:
nbn Fibre to the Curb (FTTC) | nbn
You have actually come up with the answer yourself. The D7800 is not compatible with DSL but it is compatible with the modem that you use to connect to the Internet.
That is what @dJOS_500 is telling you.
In other words, bypass the modem and you are in business.
The problem is that Netgear's KnowledgeBase article is misleading. (It really would be a good idea if @ChristineT got the support team to update that article.) It says that the D7800 is compatible with NBN. That is true, but it does not say that this is only if you use the D7800 as a router and bypass the modem.
In that case, the D7800 is compatible with any Internet you care to throw at it, but it is the wrong thing to buy, or sell, if you don't need the modem bit.
The fact that NBN and Netgear don't know what they are doing should surprise no one. NBN is a case study in how not to introduce a national broadband system.
How Australia Bungled Its $36 Billion High-Speed Internet Rollout
I gather that the bill has gone up since then.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P- Mark as New
- Bookmark
- Subscribe
- Permalink
The NBN was a great idea and being well executed ...... until the Conservatives got in and destroyed it on behalf of Murdoch who saw it as a threat to his Foxtel PayTV monoploly. The LNP even launched their #FraudBand policy, aka MtM, at Fox Studios in Sydney, doesnt get more blatant than that!
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey mate, all you need to do for NBN FTTC with this router is the following:
log in to your router> select internet tab> country Australia> select service provider if not listed select other> do not check the use VLANID> check no for does your internet require a log in> internet IP Address check get Dynamically from ISP> Domain Name server (DNS) check get automatically from ISP> Router MAC Address check Use Default Adress.
one final step you may need to do is go into your advanced tab at the top left of the page> click the setup tab> click on WAN Setup> under WAN preference select Must use Ethernet WAN.
You should be good to go from here. Hope this helps.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Politicians get in and upscrew a decent engineering project? Who would have thought it?
- Bookmark
- Subscribe
- Permalink
Good input.
If @DarcyVM can confirm that this works for them, it would be good to mark this as Solved. That would help other victims who turn up with the same issue.
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
You have joined in on an existing conversation that may or may not have anything to do with your problems.
There is also a good chance that the official support team is busily monitoring new conversations and may miss your addition to this one.
If you do want help with your problem, check previous stuff that may be related then start your own discussion.
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
@dJOS_500 wrote:
You can’t use anything but the NBN FTTC modem, NBN won’t allow it.
Really? Some people seem to succeed.
Then again, NBN is implemented by many different Internet service providers.
Here's a good place to start:
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks @Simon-C. This got me most of the way to connecting for iinet fttc.
The only differences I needed to use for iinet came from the webpage https://help.iinet.net.au/o/iinet-broadband-settings-list
I needed to change: service provider to "other", set VLAN ID to 2 and to leave the login name and password active. All other settings (including "use ethernet/WAN") were the same. Hope this helps the next person.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hi I have used the above instructions but cannot connect to NBN. It's all very odd as I connected fine a month ago. The NBN box stopped working. It's been replaced but I can't get back on and my ISP have been no help. What can I do next?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You have just joined in on an year-old discussion.
We have no idea if your system is anything like the original.
We don't know what instructions you followed and where it went wrong, or why you took a ride on this conversation.
Remember, FTTC on NBN is not DSL (see above), which is what the D7800 works on.
You'd stand a better chance of getting help if you started a fresh conversation with more details of your set up.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P• What is the difference between WiFi 6 and WiFi 7?
