Orbi WiFi 7 RBE973
Reply
Nighthawk d7000 power outage causing issues
Vegemite
Follower
I had a power outage and now only the internet and dsl light dimly light up no power light etc... cannot connect to internet I've tried resetting it unplugging it for an hour still nothing. I'm not savvy with technology and have no idea what else to try. Any help would be appreciated
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
antinode
Guru
Re: Nighthawk d7000 power outage causing issues
> light up no power light etc... [...]
   Sounds to me like hardware -- power adapter or modem+router.
   I'd test/substitute the power adapter.  (Same polarity and voltage,
similar/adequate current.  But even one with a lower current rating
might serve for a short test.)  It's a 12V device, so, if your dexterity
is good enough, and you're careful, even a car battery could work.  (Not
a good idea if you're ignorant, stupid, clumsy, or careless.)
Message 2 of 2
Discussion stats
  • 1 reply
  • 486 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
