Orbi WiFi 7 RBE973
Reply
No internet connection via WiFi
PradeepJ
Follower
Hello, hope someone can help me:
Internet connection is no problem with the PC connected directly to the router. However via a Wifi connection I cannot get any internet connection to a laptop with Wifi security enabled. With no Wifi security enabled no problems. With any sort of security enabled, the laptop makes a strong Wifi connection but no internet.
I've tried all the available security options to no avail.
Any help would be much appreciated. I only bought this two weeks ago and I cannot find the receipt to return this.
Thanks heaps
Model: D6200v2|AC1200 WiFi DSL Modem Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: No internet connection via WiFi
Hello PradeepJ
I would clear save wireless networks from your laptop and make a new connection to the router also may want to try and rename the SSID in case the laptop is saving some strange settings causing it to get not internet.
DarrenM
Message 2 of 2
Discussion stats
  • 1 reply
  • 1907 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
