Orbi WiFi 7 RBE973
Reply
PLEASE HELP ME ! N300 DGN 2200
Quintin89
Follower
I also have a quick question I have 2 wifi Names my main wifi network that im connected to the other 1 is the Guest Network wifi so that the guest can also connect to my home wifi is there anyway i can set setting to the guest network like that they cant download anything or have a certain amount data pm to use.
Because we have a someone staying here and I gave them the Guest login details but they keep on downloading and using all the data and I need to do something about this.
Hope there is something I can do. Because me and my family are connected to the main wifi. I HAVE THE N300 WIRELESS DGN 2200 ROUTER
Regards
Quintin
Message 1 of 2
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: PLEASE HELP ME ! N300 DGN 2200
Hello Quintin89
You can use parental controls to only allow them on the Internet during certain times so they cant leave there pc on to download things all the time. But there isn't a way to only allow 1 device to shut off if it reaches a download limit you can do it for the whole router.
DarrenM
Message 2 of 2
All Replies
DarrenM
Hello Quintin89
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3009 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi 770 Series
