Orbi WiFi 7 RBE973
Reply
Parental controls on indervidual devices on DEVG2020
AmandaJB
Hi, I have downloaded Netgear genie onto my computer and phone but am unable to access the parental controls section.
Message 1 of 4
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: Parental controls on indervidual devices on DEVG2020
Hello AmandaJb
That model is a ISP modem and does not have Genie app support
http://kb.netgear.com/app/answers/detail/a_id/24686?cid=wmt_netgear_organic
DarrenM
Message 2 of 4
All Replies
DarrenM
Hello AmandaJb
DarrenM
Message 2 of 4
AmandaJB
What is the best way to set parental controls on DEVG2020 Please
Message 3 of 4
DarrenM has explained that you cannot do what you want on the DEVG2020.
Your best place to get advice is the ISP that supplied the hardware. They may be able to advise you if you can buy a different modem that will let you  set parental controls.
Alternatively, you may be able to add a router to your network and use that to set parental controls.
Just another user with a set of boilerplate macros.
My network DM200 -> MK93; R7800 -> GS316 -> PL1000 -> R7000P
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3352 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
