Orbi WiFi 7 RBE973
Reply
Readycloud on a preowned d7000 nighthawk
Majorstrife
Follower
Hi
Is it possible to connect a d7000 to ready share if it's been pre owned? Just bought the d7000 second hand everything is working fine other than the ready share feature.
When I go the the ready share web portal the transcend hard drive is not found and I can't register the router on my account because it has been pre registered.
Is there a work around to this issue or will I not be able to connect to my hard drive away from my home network?
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
Re: Readycloud on a preowned d7000 nighthawk
You'll have to get someone to connect your hardware to your account.
Do you known who sold you the device? Can they delete their registration?
You have a couple of options, try to find a local contact number (it may be well hidden) or send a private message to one of the Netgear moderators here.
If you are really lucky, someone like @DarrenM or @ChristineT will take pity on you and step in. Or send one of them a private message with your serial number.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 512 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
