- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Router says WiFi Connection is "not enabled
- Mark as New
- Bookmark
- Subscribe
- Permalink
I am connected to the router but says when I checked it, the WiFi Connection says "NOT ENABLED" and I know everything is correct. I checked to see if I can use the internet and it works fine but I dn't understand why it says that the WiFi Connnection says "NOT ENABLED." Please help me solve this issue so I won't see this problem again.
Model: 4B345C7JA39DE
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Router says WiFi Connection is "not enabled
Are you connected to Internet via wireless or wired?
- Mark as New
- Bookmark
- Subscribe
- Permalink
You may see this if you use the Netgear Genie to map the local network and go for the wifi option from a PC that is connected by LAN.
It means that you are not connected by wifi, not that the wifi isn't working. In other words, the wifi is not enabled on the PC.
Maybe this is what you are seeing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
If one is addicted to Genie and does not want to learn to control his/her router manually, (s)he is hooked to only Netgear routers.
When other brand routers like ASUS or Linksys, D-link router is encountered there is no Genie. What are you going to do?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If I understood your point, I feel sure that I might agree with you.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Have no clue why the wifi is not enabled? Hard wired
- Mark as New
- Bookmark
- Subscribe
- Permalink
So what do I need to do to enable my wifi
- Mark as New
- Bookmark
- Subscribe
- Permalink
So what do I need to do to enable my wifi Model # CG300Dv2, N450
- Mark as New
- Bookmark
- Subscribe
- Permalink
The CG300Dv2 is not something that appears in the Netgear range.
Is it, as Google suggests, supplied by an ISP?
If so, have you asked them?
