Orbi WiFi 7 RBE973
Reply
Schedule WiFi on/off
G_Pap
Tutor
Hello there,
I can schedule my WiFi signal to turn off by selecting the option from Advanced->Wireless settings.
But what if some days (e.g. holidays) I want to turn my WiFi back on after it turns off.
Is there an option for that ?
I tried to simply press the WiFi button on my device but nothing happens.
It seems like the only solution here is to use cable 🙂
Any advice please..
Thanks.
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
DarrenM
Sr. NETGEAR Moderator
Re: Schedule WiFi on/off
Hello G_Pap
If you disable the wireless then the only way to enable it again is to log back into the router via Ethernet.
DarrenM
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2764 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
