Orbi WiFi 7 RBE973
Reply
Set up wireless access point but wireless devices fail to obtain ip address
jhyfre3ak
Hi, i wanted to set my D7000 as AP router. My main router is Sagemcom F@st 3864 from Optus isp (australia).
First, i set D7000 as bridge mode as i did these steps:
1. Change LAN ip address to 192.168.0.100
2. Disable DHCP
3. Connect LAN port to main router's Lan port
Successful wired internet connection and wireless on the same device but other wireless devices failed
So instead i did other option, enabling Wireless Access Point under advanced settings of D7000. I followed instructions from this link
http://kb.netgear.com/app/answers/detail/a_id/24104/~/how-do-i-change-my-nighthawk-router-to-ap-mode...
i set dynamiccaly= Successful wired internet connection but wireless devices failed to obtain ip address
Any idea how to solve wireless issue? I am not very experienced
Thanks!
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 3
Accepted Solutions
jhyfre3ak
Re: Set up wireless access point but wireless devices fail to obtain ip address
i just fixed it a while ago. For AP mode, you plug LAN port of main router to WAN port of D7000 (not LAN to LAN). I wish i figured it out so much earlier.
Message 3 of 3
All Replies
DarrenM
Sr. NETGEAR Moderator
Hello jhyfre3ak
I would try to factory reset the D7000 then do the AP mode again could be a old setting causing the issues.
DarrenM
Message 2 of 3
jhyfre3ak
Message 3 of 3
Discussion stats
  • 2 replies
  • 5270 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
