Orbi WiFi 7 RBE973
Reply
Unplugged my DG834GU v5 and when i plugged it back in it wont work.
Bubblegrub
The PC recognises it but it's not connecting. I'm a real novice. Any suggestions?
Model: DG834GUv5|Integrated ADSL2+ Modem and Wireless Router with USB
Message 1 of 3
DarrenM
Sr. NETGEAR Moderator
Re: Unplugged my DG834GU v5 and when i plugged it back in it wont work.
Hello Bubblegrub
You may want to do a Factory reset the modem by holding down the reset button for 10 seconds so you can go through and do the internet setup again.
DarrenM
Message 2 of 3
Bubblegrub
Hi DarrenM
Thanks. I will give that a go.
Message 3 of 3
Discussion stats
  • 2 replies
  • 2568 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
