Orbi WiFi 7 RBE973
Reply
Using as access point only, connected to 24 port switch
chiefgeek
Follower
Hello,
I need to set this up as an access point only, extending the existing network. We have a Comcast business class modem/router connected to a 24 port switch, using 192.168.50.1 as the default gateway. Anything wireless we need to be in this network as to reach the server where our dental management software/database resides. Thank you in advance for any help.
Message 1 of 2
fordem
Mentor
Re: Using as access point only, connected to 24 port switch
1) Set the router's LAN address to a suitable address (presumably you have a range of addresses set aside for static address use) and disable the DHCP server. 2) Connect the router to your network using one of it's (the router's) LAN ports. 3) Point your browser to the router's ip address and configure the wireless as required.
Message 2 of 2
Discussion stats
  • 1 reply
  • 7676 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
