Orbi WiFi 7 RBE973
Reply
VDSL Modem problems with setup
Stikemanley
Follower
Just purchased DM200
Followed instructions: It didn't take so I repeated.  Now when I plug in phone line, then power and get all green I add the ethernet cable to my computer and the browser opens but nothing happens.  Eventually I get the following response:  "The GCI script took too long to porduce a response."  So I can get off square one to set anything up.
Message 1 of 2
Re: VDSL Modem problems with setup
Is that the initial startup wizard? Or are you throwing the browser at the thing to see that message?
Have you reset the modem to factory settings?
The documentation for your hardware is here:
>>> DM200 | Product | Support | NETGEAR <<<
Message 2 of 2
Discussion stats
  • 1 reply
  • 1408 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
