Orbi WiFi 7 RBE973
Reply
VPN between iPhone and router - Familoop
kilfinan
Tutor
I've recently installed Familoop Parental Control on my daughters iPhone but am haveing problems keeping a VPN connection.  IT either fails to connect, drops the connection or, when connected, blocks internet access.
Can anyone advise where I am going wrong.
Thanks
Model: D6400|AC1600 WiFi VDSL/ADSL Modem Router|802.11ac Dual Band Gigabit
Message 1 of 2
OlegKrasnov
Re: VPN between iPhone and router - Familoop
Hi Kilfinan,
I regret to learn that you faced with this issue. First thing we should try is reconnect to Familoop's VPN. In order to do this, please follow the steps below:
  • Go to Settings > General > VPN
  • You should see 'Familoop VPN' listed
  • Check mark to the left of the 'Familoop VPN' must be selected
  • In 'Familoop VPN', tap on the 'i' to the right. Turn off the 'Connect On Demand' option
  • Delete all profiles from device
  • Enroll device again using the Familoop app
Best regards, Oleg Krasnov
Familoop Support Team
Message 2 of 2
Discussion stats
  • 1 reply
  • 3239 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi 770 Series
