× We are aware of an issue affecting Nighthawk CAX30 Cable Modem Routers that may have resulted in an interruption of internet service. For instructions to restore Internet connectivity click here.
Reply
W300 WIFI not working, wifi indicator does not lit up, tried factory reset
Rockyg
Follower
W300 WIFI not working, wifi indicator does not lit up, tried factory reset. My internet is working when directly connected to the laptop. Wireless icon does not blink, WIFI SSID is not searchable. Would there be a  hardware problem as internet and powere icon are lit up but not wifi. what can be the solution. Should I throw it away and but a new one, this is the second modem that turned out to be a dud.
Model: DGN2200-4DDAUS|N300 Wireless ADSL2+ Modem Router
Message 1 of 2
Re: W300 WIFI not working, wifi indicator does not lit up, tried factory reset
Tried the wifi switch?
It might not look like it, but the wifi icon is also a switch.
By the way, the original DGN2200 dates back to 2011. It has slow Ethernet ports (100-Base rather than 1000) and does not seem to support 5GHz wifi.
Just another user with a set of boilerplate macros.
My network DM200 -> R7800 -> GS316 -> PL1000 -> Orbi RBR40 -> Orbi RBS50Y -> RBS40V
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 552 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 6E
