Orbi WiFi 7 RBE973
Reply
What is the difference between R7000 UKS100 and UKS200 versions?
megurushi
Tutor
HI, looking to buy the R7000 but want to know what the difference is between them.
Very little I guess, the 200UKS shows the info from the 100UKS product page on Amazon!
The ports on the back are different and the 100UKS has an LED off switch.
100UKS:
https://www.amazon.co.uk/dp/B00ZU1T8C0/ref=psdc_430578031_t1_B00HDK4GAK
 100UKS back100UKS back
200UKS:
https://www.amazon.co.uk/NETGEAR-D7000-200UKS-Nighthawk-Wireless-Connections/dp/B074QMGFNY/
200UKS back200UKS back
Model: R7000|Nighthawk AC1900 Dual Band WiFi Router
Message 1 of 3
megurushi
Tutor
Re: What is the difference between R7000 UKS100 and UKS200 versions?
D7000 not R7000 Smiley Mad
Message 2 of 3
DarrenM
Sr. NETGEAR Moderator
The v2 has no WAN connection but other than that they are the same.
DarrenM
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 2405 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
