Orbi WiFi 7 RBE973
Reply
What's happen with D7000 1.0.0.26 firmware???
polemikus
I have noticed that new firmware ver. 1.0.0.26 has been removed from Netgear support site. Does anyone have some details about it???
Message 1 of 13
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: What's happen with D7000 1.0.0.26 firmware???
Hello polemikus
We found some issues with the firmware and had to take it down the engineers are working to fix this and  will re release the firmware soon.
DarrenM
Message 2 of 13
All Replies
DarrenM
Hello polemikus
DarrenM
Message 2 of 13
michty_me
Is the firmware on the website the revised firmware? There is a bit of confusion due to the firmware version numbers being the same.
Message 3 of 13
clithes
Prodigy
I was thinking that.  The release notes have changed but the firmware size and compiled time/date are exactly the same
Modem: Vigor 130 | Routers: R7800, R8500 & R9000 | ISP : Plusnet Unlimited Fibre Extra
Powerline: PLP1200x4 PL1200x6 | WiFi Extenders: PLW1000 & XWN5001
Switches: GS105Ex2, GS105Ev2, GS108Ev2, GS305
Message 4 of 13
michty_me
Yup, i noticed this too. Have they accidentally uploaded the wrong one?
What changes are in the revision notes from the previous one?
Message 5 of 13
DarrenM
I am checking on this I will let you guys know once I hear something.
DarrenM
Message 6 of 13
Buckchoi
Guide
The re-uploaded firmware is exactly the same as it was before it was removed (hash identical), and the contents of the release notes are also the same.
Message 7 of 13
yakidoda
Hi
One this I noticed with this router update is that the first ping to anyone is always higher than the rest.
Pinging google.com [216.58.198.206] with 32 bytes of data ;
Reply from 212.58.246.79: bytes=32 time=32ms TTL=55
Reply from 212.58.246.79: bytes=32 time=15ms TTL=55
Reply from 212.58.246.79: bytes=32 time=14ms TTL=55
Ping statistics for 212.58.246.79:
    Packets: Sent = 4, Received = 4, Lost = 0 (0% loss),
Approximate round trip times in milli-seconds:
    Minimum = 14ms, Maximum = 32ms, Average = 18ms
Kev
Message 8 of 13
yakidoda
Hi again
Update to my post above, the first ping is high bit. After using
http://kb.netgear.com/app/answers/detail/a_id/19863/~/ping-test-to-determine-optimal-mtu-size-on-rou...
my pings are optimized, all the same now, see below, MTU 1490 was mine but the guide wiill point you to whats best for you.
Pinging google.com [62.24.208.187] with 32 bytes of data ;
Reply from 62.24.208.187: bytes=32 time=6ms TTL=60
Ping statistics for 62.24.208.187:
    Minimum = 6ms, Maximum = 6ms, Average = 6ms
Kev
Message 9 of 13
yakidoda
Spoke to soon this router has a problem that has appeared before on Netgear routers a high first ping
Pinging www.google.com [62.24.208.172] with 32 bytes of data ;
Reply from 62.24.208.172: bytes=32 time=41ms TTL=60
Reply from 62.24.208.172: bytes=32 time=9ms TTL=60
Reply from 62.24.208.172: bytes=32 time=10ms TTL=60
Ping statistics for 62.24.208.172:
    Minimum = 9ms, Maximum = 41ms, Average = 17ms
Kev
Message 10 of 13
michty_me
So what were the problems? Is the firmware on the download section the re-released version?
Message 11 of 13
DarrenM
michty_me
yes this is the original the engineers couldn't reproduce the issue that was reported for the reason it was taken down. According to the engineer the issue is related to iOS9.1 and user’s Apple TV since it does not seem to support 5G connection at lower channels. that they took it down so it was put back up.
DarrenM
Message 12 of 13
michty_me
Thanks for confirming.
Message 13 of 13
Discussion stats
  • 12 replies
  • 4503 views
  • 3 kudos
  • 6 in conversation
Announcements
Orbi WiFi 7
