- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Wlan im AC Mode Nachts ausschalten D700v2
- Mark as New
- Bookmark
- Subscribe
- Permalink
sorry, finde hier keine wirkliche Antwort.
Kann ich das Wlan wenn der D700v2 im AC Mode läuft nachts über die Zeitschaltung abschalten?
Er nimmt zwar die Einstellung, macht es aber nicht. Was mahe ich falsch?
Danke Euch 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Wlan im AC Mode Nachts ausschalten D700v2
"AP Mode"? "D7000v2"? Firmware version?
It should work; I don't see "Turn off wireless signal by
schedule" on the list of disabled features:
Does the D7000v2 have the correct time?
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Read. Look for "Set Up a WiFi
Schedule", and the Note there about the clock. Check the timezone, too?
How, exactly, is the D7000v2-as-WAP connected to your main router?
When it tries to communicate with a time server, it might use only its
"LAN 4 / Ethernet WAN" port. It's a D7000v2, so a firmware bug would
not be amazing.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey,
thank you very much and sorry for my bad english.
I have changed the ntp to the same ntp like my main router and hope it works.
I test it tonight and tell you how it go.
Have a nice day 🙂
- Mark as New
- Bookmark
- Subscribe
- Permalink
i have test it but it doenst works.
I use it in Access Point Mode and my Software is v1.0.0.66_1.0.2
Its connect via wan to my main router
do you have an idea to solve the problem?
thank you, have a nice day 🙂
• Introducing NETGEAR WiFi 7 Orbi 770 Series and Nighthawk RS300
