Orbi WiFi 7 RBE973
Reply
i cant login to router model n600
sawalha
Follower
i bought a used netgear router and i cant login i rest my router and i cant login avry time i try to login give me this
404 Not Found
The resource you have requested is not available.
Model: D3600|N600 WiFi Modem Router - 802.11n Dual Band Gigabit
Message 1 of 2
antinode
Guru
Re: i cant login to router model n600
   "i cant" is not a useful problem description.  It does not say what
you did.  It does not say what happened when you did it.  As usual,
showing actual actions with their actual results (error messages, LED
indicators, ...) can be more helpful than vague descriptions or
interpretations.
> i rest my router
   How, exactly?  Normally, a proper reset will restore the factory
default user+password credentials ("admin", "password").
   "login" how, exactly?  Are you using some web browser or other, on
some computer or other, specifying some URL or other, and then providing
some user name and password or other?
> 404 Not Found
   If the router does that for no good reason, then it would seem to
have corrupt/defective (and/or non-Netgear) firmware.  But, based on
only "i cant login", it's hard to be sure of anything.
   If all else fails, then there is with the last-ditch/emergency TFTP
recovery scheme:
      https://kb.netgear.com/22688/
   I know nothing, but some reports here suggest that, on Windows, the
built-in command-line TFTP client works better than the "tftp2.exe"
program shown there.
   If you have not already done so, then visit
http://netgear.com/support , put in your model number, and look for
Documentation.  Get the User Manual.  Read.
Message 2 of 2
Discussion stats
  • 1 reply
  • 1323 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
