Orbi WiFi 7 RBE973
Reply
remote management: from this PC / everyone
eciesse
If I try to enable remote management and to open for "everyone" I cannot save my settings. When I click on apply it goes back to "only this PC" setting.:(
everything works ok from that PC using the WAN IP (so the remote management is reallu on) but I cannot access the router from other PCs (obviously as the settings are saves as "only this PC")
Why I cannot change that setting?:confused:
thanks
Message 1 of 4
Geoff_Vass
Re: remote management: from this PC / everyone
Access the web interface with Firefox instead of IE
Message 2 of 4
eciesse
thanks! it was SOOO easy. But It was NOT a problem of only IE... I had that doubt and I tried with IE Chrome Safari on MAC Safari on Ipad always the same BAD result!! With Firefox it worked at the first try! I have to switch to firefox... thanks again
Message 3 of 4
additude
Virtuoso
You need to add IE to compatibility mode of the router. IE->Tools->Compatibility View..... Put your routers IP in there.
Message 4 of 4
Discussion stats
  • 3 replies
  • 7791 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
