Orbi WiFi 7 RBE973
Reply
speed & duplex
adora_9015
speed & duplex
i bought router dgn1000v3 it works well in wifi but when i connect pc or laptop with cable the pc get unplugged cable but the cable already connected when i searched about this problem i found the solution in speed & duplex option in net card properties advanced must changed to 10 mb full duplex.
my question : is there any option in the router to make speed & duplex work with option auto Negotiation not only 10 mb full?
thanks
regards
Model: DGN1000v3|N150 Wireless ADSL2+ Modem Router
Message 1 of 28
VE6CGX
Master
Re: speed & duplex
Your network card(NIC) has a advanced setting section on their driver. If you OS is wondows from device manager >> right click NIC
card >> click property >> advanced setting >> there you will see it.
Message 2 of 28
adora_9015
Re: speed & duplex
i know where can i find it im asking about speed & duplex option when i connect a cable from router to my computer it must be 10 mb full
if i choose 100 mb or auto option it never work and get unplugged cable
i need it to work with 100 mb or auto option
is there any way to do this?
Message 3 of 28
TheEther
Guru
Re: speed & duplex
The ports on the router are auto-sensing.  Your Ethernet cable may be bad.  Try a different one.
Message 4 of 28
VE6CGX
Master
Re: speed & duplex
That is the problem with the ADSL modem. Not your NIC. Deal with it with your ISP then. Knowing it how come you raise a question?
What is your modem specs.? Ca it handle 1oombps speed?
Message 5 of 28
adora_9015
Re: speed & duplex
i tried many cables the same problem
Message 6 of 28
adora_9015
Re: speed & duplex
i call my ISP but they didnt know where is the problem
my modem netgear dgn1000v3
Message 7 of 28
adora_9015
Re: speed & duplex
Message 8 of 28
adora_9015
Re: speed & duplex
anyone can help?
Message 9 of 28
TheEther
Guru
Re: speed & duplex
What's the model of your Ethernet card?
Message 10 of 28
adora_9015
Re: speed & duplex
Realtek PCIe FE Family Controller in laptop dell 5520
and atheros ar8151 pci-e gigabit in pc
but they was work well before this problem happened when i bought netgear router
Message 11 of 28
VE6CGX
Master
Re: speed & duplex
I think you are asking too much from the ADSL2+ modem. Typical sync. 'd speed of ADSL
modem is ~10mbps and I saw peak at somehing like 25mbps.
Message 12 of 28
adora_9015
Re: speed & duplex
sorry cant understand
Message 13 of 28
TheEther
Guru
Re: speed & duplex
It sounds like the Ethernet ports on the router are broken if they only sync at 10 Mbps.  Maybe you can try inserting a switch between the router and your computers and see if that helps.  Otherwise, return the router.
Message 14 of 28
adora_9015
Re: speed & duplex
now i inserting a switch between the router and computers and the same problem
Message 15 of 28
adora_9015
Re: speed & duplex
there is one pc works with auto option in speed & duplex, the main pc with router
Message 16 of 28
TheEther
Guru
Re: speed & duplex
Your messages are unclear.  First you said you have the same problem when inserting a switch.  Then you said the main PC works.  Which is correct?
Message 17 of 28
adora_9015
Re: speed & duplex
the person who has the internet service in his line phone, his computer works with auto option,
any computer else only work with 10mb full duplex
Message 18 of 28
TheEther
Guru
Re: speed & duplex
Sorry, it's still unclear.  Is the computer that works with auto negotation plugged into a switch or directly into the router?
The other computers that only work at 10 Mbps are also plugged into the switch or are they still plugged directly into the router?
Message 19 of 28
adora_9015
Re: speed & duplex
the computer that works directly plugged into the router
The other computers that only work at 10 Mbps i plugged them into a switch and directly into the router but the same result
Message 20 of 28
VE6CGX
Master
Re: speed & duplex
Can't understand? Then I suggest you to read Wikipedia on ADSL2+ modem to get
familiarize yourself with the said subject. I think your ISP is playing dumb to ignore
your question or concern.
Message 21 of 28
TheEther
Guru
Re: speed & duplex
If the computers only work at 10 Mbps while plugged into the switch, then the router is not the problem. There's something wrong with the computers.
Message 22 of 28
VE6CGX
Master
Re: speed & duplex
Auto option is not important in this case. Either way it must be capped at 10mbps from ISP, then auto option is throttling down to 10mbps. It becomes non-issue. It is impossible to obtain 100mbps speed from 10mbps line.
Message 23 of 28
adora_9015
Re: speed & duplex
i tried my laptop with both switch and router and got the same problem
but if you know where is the problem in computers tell me
Message 24 of 28
VE6CGX
Master
Re: speed & duplex
Message 25 of 28
Top Contributors
Discussion stats
  • 27 replies
  • 7213 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi 770 Series
