Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
3700v2 portforward: does internal port# have to be same as external port#?
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-05-08
10:57 PM
2014-05-08
10:57 PM
I just purchased a 3700v2
I need to map WAN ports on router to different internal ports. I cannot figure out how to do this on this confusing setup. If that is true it is the first router I'[ve ever used that couldn't do it.
Is it true?
Message 1 of 9
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-05-08
11:06 PM
2014-05-08
11:06 PM
Re: v2 router problem with port forwarding
I think I have same problem and judging by no one answering your question, I'd say we might be screwed. It appears external port must be equal to internet. This is the first router I've used that had this problem. That is a serious limitation/flaw. They should fix the firmware/setup if so.
Message 2 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-05-09
05:59 AM
2014-05-09
05:59 AM
If port translation is supported you will find in port forwarding rules. If not it means it does not support.
Most netgear consumer line do not supper it. R7000 does
Message 3 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-05-09
06:03 AM
2014-05-09
06:03 AM
Re: 3700v2 portforward: does internal port# have to be same as external port#?
If not shows as an options then it does NOT support.
Netgear consumer line do no support port transition to to choose external port to internal ports.
R7000 does support
R7000 does support
Message 4 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-05-09
08:47 AM
2014-05-09
08:47 AM
That is amazing. It is first router I've used that did not support it.
Message 5 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-05-10
03:16 AM
2014-05-10
03:16 AM
Nogero, please don’t post the same question in more than one thread.
Message 6 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-06-01
05:14 AM
2014-06-01
05:14 AM
@nogero , You may be able to do it setting port mappings via a uPnP client (V1 lets you do it this way).
In a Linux OS a client such as 'UPnP Router Control' will do it if you want a GUI.
Message 7 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-06-10
06:26 AM
2014-06-10
06:26 AM
The "To add a custom service:" section of the help documentation describes setting a internal port and an external port. That help document also states that it applies to the DGND3700v2. http://kb.netgear.com/app/answers/detail/a_id/24046
Message 8 of 9
- Mark as New
- Bookmark
- Subscribe
- Permalink
2014-07-04
07:21 AM
2014-07-04
07:21 AM
Unfortunately that help documentation is incorrect and the DGND3700V2 does not have the pictured options when port forwarding, simply a name, a type, a start port for the range, and an end port for the range field. This is annoying as hell.
Message 9 of 9
Announcements
