- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1600 cable modem router and AC2100 router
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1600 cable modem router and AC2100 router
"AC1600" is a speed, not a model number. Ever helpful, Netgear
product packaging emphasizes speeds like "ACxxxx", but that's not the
model identifier. Look at the product label for the actual model
number.
> Model: D6400|AC1600 WiFi VDSL/ADSL Modem Router|802.11ac Dual Band
> Gigabit
Is that accurate? "cable modem" normally implies cable-TV, not DSL.
To maximize confusion, Netgear has started using things like "AC2100"
as model numbers on a few models, so you can't rely on much other than
the product label.
Visit http://netgear.com/support , put in your model number
("AC2100"), and look for Documentation. Get the User Manual. Look for
"Set Up the Router as a WiFi Access Point".
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
> [...] can I have the same SSID on both or do I have to have another
> SSID? [...]
Run the experiment?
I'd expect the same SSID(s) on both devices to be ok, especially if
you can't detect the signal from both in either building.
- Mark as New
- Bookmark
- Subscribe
- Permalink
