- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1600 with Netgear Genie, Can't stop speed test
- Mark as New
- Bookmark
- Subscribe
- Permalink
Started speed test in Genie and it runs continously. How can I stop it?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1600 with Netgear Genie, Can't stop speed test
You refer to the genie. This could be one of several things, the browser interface, a Windows or Mac program for a PC, or a mobile Android/iThing app. Netgear labels them all as genies. Which are you using?
AC1600 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Take us through the moves you make and describe what is happening. Then someone might understand what is going on.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Modem Router is Netgear AC1600 WiFi Cable Modem Router 802.11 ac Dual Band Gigabit with Built-in DOCSIS 3.0 Cable Modem Model C6250 for Spectrum.
Netgear Genie is an installed program from Netgear. Version 2.4.62. In the center-right of the Genie screen (when it is open) there is a small grey box labelled "Speed Test" followed by "or go to http://www.speedtest.net".
I clicked on the Speed Test box and it has been running the speed test continuously since that moment. That is more than a day now. I have shut down the Netgear unit (power off) for some time (overnight) and when powered up again it goes right on with the speed test.
This is on a PC running Microsoft 10 OS. How can I stop it?? Screen shot attached.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Take your pick.
- Go to a different tab in the genie (Home would be a start)
- Uncheck the Download and Upload boxes on that page
- Exit the desktop genie from the notification area.
- Disable Autostart in the notification area.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Possibly good suggestions, BUT - In the Home screen there is no access to the Download and Upload boxes so can’t uncheck them there. I can’t exit or disable AutoStart in the Notification Area since there is nothing labeled that way and otherwise I have no idea what area you are referring to. By the way, it is still running – and running – and running – and running - - - -
- Mark as New
- Bookmark
- Subscribe
- Permalink
Those boxes are on the screen that you originally posted.
Forget the HOME tab.
That is seriously strange. Where are you looking?
It is there visible for me. Along with the other things.
You do know what the notification area/Taskbar is? And how to enable/disable icons there?
I am beginning to think that this speedtest is not running at all. You just see it when you land on the right/wrong place. You won't see it on the HOME tab because it isn't active.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Boy, you have me confused. You tell me that the boxes to uncheck are right there in plain sight, BUT you indicate that I will find them in the "Home" tab. Please note that the ones in my screenshot are NOT in the Home tab, but in the "Internet" tab. When I uncheck them in the one screen where they are present, it does not stop the speed test. It hides the display, but the speed test goes on. You can see it go on if you look at the up and down arrows with xxMbps at the lower edge of the speed display, and when you again check the boxes you can again see it going in on the graph and still moving steadily to the left on the screen.
- Mark as New
- Bookmark
- Subscribe
- Permalink
And I have inspected the screens shown by every one of the labels in the left taskbar and nowhere does it show anything like the "Genie Notification Area" that you have included in your message. I suspect you and I are looking at very different versions of the Genie program.
- Mark as New
- Bookmark
- Subscribe
- Permalink
No, I have the same version. I checked.
There is no genie notification area. As my image showed, it is the Windows notification area. I never said the boxes were on the Home tab. That was you. My image showed where to look. The Internet tab.
It is becoming increasingly clear to me that you really don't have a problem with the genie, just with your understanding of how it, and Windows, work.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Where did you get that idea from? Read my message again. Look for the bit that said:
How can read that to mean that you should look at the Home tab?
Puzzling.
You have got this all wrong. Those bars have nothing to do with speed test. They show the traffic in and out of your router.
Speedtest is something very different. It is what happens when you press the Speed Test button. Press that and the genie goes out and measures the speed between you and www.netgear.com. (You can try different addresses.) Then it fills in the next line. Below that address.
This is a one-off event. (Watch as the button "greys out".) It is not related to the bar chart. Speedtest is not running all the time.
That is not a speedtest. It is a measure of your traffic in and out.The only way to stop that is to exit from the genie, as already explained, or stop using the Internet.
