- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
AC1900 After around 10 months use the two wireless radios failed
- Mark as New
- Bookmark
- Subscribe
- Permalink
A firmware update from 1.0.0.26_ to 1.0.0.38_ did not help.
Wired still works fine.
A review of the firmware settings could identify no reasonsw.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: AC1900 After around 10 months use the two wireless radios failed
contact support via MYNetgear if you registered it
- Mark as New
- Bookmark
- Subscribe
- Permalink
I tried registering the D7000 AC1900 Nighthawk dual-band wireless router.
The first time Netgear reported a server error
The second that the 13 digit serial number was wrong. Well they printed it on the device!
The third that the date of purchase was outside their manufacturing range.
So how do I contact them to get some response?
- Mark as New
- Bookmark
- Subscribe
- Permalink
If the device wounldn't register, I guess you should had dealt with it back then, When you had the power to return it. I'm not sure what you can do about it now. They're all geared up to go through the MyNetgear process.
Good Luck
- Mark as New
- Bookmark
- Subscribe
- Permalink
Did you reset to factory settings?
This is sometimes needed after a firmware flash.
