Orbi WiFi 7 RBE973
Reply
AC750 router, do i need a seperate modem?
henrikleine
I have just bought a new AC750 dual band router, but when i try to connect a website poppes up and it says 403 forbidden, is that because i dont have the router connected to a Modem?
Model: D6000|AC750 WiFi Modem Router - 802.11ac Dual Band Gigabit
Message 1 of 4
henrikleine
Re: AC750 router, do i need a seperate modem?
it is not the D6000, but i was not able to use the AC750/ R6020 when i created the post
Message 2 of 4
That's because you posted in the DSL modem area
AC750 is not a model number. It is a wifi speed label.
What is the model number of your AC750?
model number
Message 3 of 4
antinode
Guru
> I have just bought a new AC750 dual band router, [...]
   And connected it to what?
> [...] but when i try to connect a website poppes up and it says 403
> forbidden, [...]
   What, exactly, did you do?  What, exactly, happened when you did it?
As usual, showing actual actions with their actual results (error
messages, LED indicators, ...) can be more helpful than vague
descriptions or interpretations.
> [...] is that because i dont have the router connected to a Modem?
   Perhaps, but the non-psychics in your audience know very little about
what you're doing, what your ISP is, what's connected to what, and so
on.  This ignorance makes specific advice hard to supply.
   General advice: Visit http://netgear.com/support , put in your
(actual) model number, and look for Documentation.  Get the User Manual.
Read.
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 2489 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
