- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Android devices not loading some websites or apps d7800
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hey guys, Ive just purchased a new d7800 x4s nighthawk modem router,
I'm certain I set it all up correctly however im having issues with my galaxy tab s and galaxy s6 edge,
When I connect these devices to the wifi, certain websites fail to load like www.netflix.com and the app refuses to load also and a few others.
How ever google and play store work, Everything works fine on mobile data. but when i try to load netflix.com on wifi i'll get a error like
No data received
or time out
I've gone through most setting on the router and can't seem to find any settings that would cause this, I've even added the tablet to dmz in case its some port forwarding issue and still no good, maybe being a new model it's a firmware thing 😕 any idea's or something I might be over looking?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Android devices not loading some websites or apps d7800
Thought I might add all websites work flawlessly on ethernet connected computer
- Mark as New
- Bookmark
- Subscribe
- Permalink
Hello Crazylife
Try to forget the network on the phone and tablet and then try connecting to the 2.4 ghz band if you were on the 5ghz before or the opposite and see if that make a difference you may also want to do a reboot of your modem and router as well. Let me know if you have tried that or it has any effect.
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Same Nighthawk, same problem.... it's driving me mad....
I've tried every setting on the Samsung Smart TV and every setting on the Nighthawk that I can find and no answers.... I hope someone can give us some further info?
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Mark as New
- Bookmark
- Subscribe
- Permalink
I was kind of stumped about this too, this is a high performance router and my phone and my wife's would stall on nearly every web request. Resetting the phone seemed to make it work at least for a bit, but that was a drag. Super smooth on PC's.
Anyway, thanks for the MTU tip, I changed to 1492 on the router and back to silky smooth internet on the phone. I doubt I would ever have discovered that without checking this thread.
- Mark as New
- Bookmark
- Subscribe
- Permalink
This MTU change also fixed the QoS speed test, that speed test didn't ever work up until I made that change.
