- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Blank entries in Modem
- Mark as New
- Bookmark
- Subscribe
- Permalink
I have blank entries in my modem on the status page its the only one in the modem, i have rebooted it any ideas how to fix this, the modem still works OK
Solved! Go to Solution.
Accepted Solutions
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's it.
There is something strange going on there.
The browser shows an IP address of 10.1.1.1.
Is there anything else on the network? An address like that usually suggests that there is another modem there that is telling the DGN2200 to use that address.
How are you getting into the DGN2200?
http://www.routerlogin.net or http://www.routerlogin.com.
You may have to reset the thing to its factory settings and set it up from scratch.
The manual explains how to do that:
>>>> DGN2200v1 | Product | Support | NETGEAR <<<<
That's why it is important to know the model number.
All Replies
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Blank entries in Modem
Picture too small to read.
What's the hardware?
- Mark as New
- Bookmark
- Subscribe
- Permalink
The Moden is a DGN300,the pic is the router status page, which used to tell me the upload and download speeds as well as other information, but it is now blank showing no information at all. The Modem is still working. I was just wondering if this could be fixed or is it a sign that the Modem is on the way out.
- Mark as New
- Bookmark
- Subscribe
- Permalink
@jeepers01 wrote:The Moden is a DGN300....
That does not exist in the Netgear support system.
Look for a label like this:
And check the model number.
- Mark as New
- Bookmark
- Subscribe
- Permalink
How does DGN2200 sound thats what is on the modem .
- Mark as New
- Bookmark
- Subscribe
- Permalink
That's it.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Well the reset to Factory worked, Thanks to all for the help.
