- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Broadband connection dropping out
- Mark as New
- Bookmark
- Subscribe
- Permalink
Now and again my router has started to drop a connection. When I check my telephone connection it comes up with the dialing tone as normal. I have fibre most of the way and normally exceed 35 mbps. I have tried turning off the router pausing and switching back on but this does not always work. Any ideas?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: Broadband connection dropping out
Hello up4alark
Are you able to check the logs on the modem when these drops happen?
DarrenM
- Mark as New
- Bookmark
- Subscribe
- Permalink
Thanks Darren.
No, I have not yet found my way into that dark room. Since my understanding of techie jargon is nil, I will see if I can discover the log and if I can, I assume I should send you a copy thereof for interpretation.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Could not find a way to highlight/copy the details to you so resorted to the folowing:-
In Event Viewer there are listed in the section titled "Summary of Admin Events" in the order of last hour/24 hours/7days,
Critical 0/0/0; Error 0/4/21; Warning 0/16/29; Information 12/316/2908; Audit Success 71/946/5974.
There are no entries under Event ID; Source or Log.
At the bottom there is a long list titled "Log Summary" detailing Size; Modified; Enabled; Retention Policy. The vast majority are "Enabled" and all have "Overwrite events as nece.." alongside.
Hope this helps ! Best Mac.
