Orbi WiFi 7 RBE973
Reply
C3000 router password problems
Bantabrooks
Tutor
I changed my router password. I was able to log back on with my smart TV but none of my apple products will accept the password: I phone, I pad, MAC.
Model: C3000|N300 Cable Gateway Docsis 3.0
Message 1 of 7
Accepted Solutions
Guru
Re: C3000 router password problems
I'd go in and forget the network on your devices. maybe its auto-filling it even after entering.
Message 4 of 7
All Replies
Guru
Did you use any special characters?
Did you go into your apple devices and "forget" the network they were on?
Message 2 of 7
Bantabrooks
Tutor
No special characters. It asked for the new password so I entered it. Should I forget first then?
Message 3 of 7
Guru
Message 4 of 7
antinode
Guru
> I changed my router password. [...]
   _Which_ "my router password"?
   Visit http://netgear.com/support , put in your model number, and look
for Documentation.  Get the User Manual.  Look for "Types of logins".
> [...] It asked for the new password [...]
   _What_ "asked for the new password"?  Why/when?  What were you doing?
   If you get desperate, then do a settings reset, and set all of them
again.  Look for "reset" in the User Manual.  Keep reading.
Message 5 of 7
Bantabrooks
Tutor
First guy solved my problem.
Message 6 of 7
Guru
You can mark the answer as solved and it both helps future people with this problem as well as it helps prevent others from devoting time to reading the thread to help fix it when its already fixed.
Btw, glad to hear you got the problem fixed!
Message 7 of 7
Top Contributors
Discussion stats
  • 6 replies
  • 2051 views
  • 2 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
