Reply
Topic Options
- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
Can not turn on D6400
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-07
03:45 AM
2019-01-07
03:45 AM
I can't turn on my D6400 router. It was working OK, then I lost connection suddenly. When I check it, I found D6400 was off. The power supply is good, but I can't turn the router on again. Is it possible to fix it? Thanks in advance.
Model: D6400|AC1600 WiFi VDSL/ADSL Modem Router?802.11ac Dual Band Gigabit
Message 1 of 7
Labels:
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-08
02:18 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-08
03:29 AM
2019-01-08
03:29 AM
Re: Can not turn on D6400
Hi Michael,
Thanks for your reply. Sorry I didn't make myself clear. The story is: I was playing online game, but lost the connection suddenly, so I went downstairs to check my router and I found all the lights in front were off, then I turn off the switch on back, unpluged the power cable and plugged again. The red light on back was on, so I presumed the power cable was good. When I turned the swich on, all the lights in front were still not on after waiting for a while. I suspect something is wrong with hardware inside. Hopefully I make myself clear this time, any questions or ideas, please let me know.
Thanks
Yong
Thanks
Yong
Message 3 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-08
04:21 AM
2019-01-08
04:21 AM
I get it now, but still don't know about the red light on the back. My D6400 has no light on the back. (Just the LEDs on the front.) Nor does the power supply.
Do you have a spare supply you can try?
Message 4 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-08
04:50 AM
2019-01-08
04:50 AM
probably because of my bad memory, could be the power cable from another router with red light on it, and I used it to rule out the cable problem. I will double check again when I get home, but I don't think it's power cable problem.
Do you think it's fixable if it was not power cable fault?
Thanks
Yong
Thanks
Yong
Message 5 of 7
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-08
06:32 AM
- Mark as New
- Bookmark
- Subscribe
- Permalink
2019-01-08
11:11 AM
2019-01-08
11:11 AM
Hi Michael,
I just confirmed it's not power supply fault.
I think I'm just not lucky to get this product, I will look for another one from other vendors.
Thanks for your help
Yong
Yong
Message 7 of 7
Announcements
