Orbi WiFi 7 RBE973
Reply
Cannot connect to routers wifi
Hayezio
Hello,
im having difficulty as i have just connected my nighthawk to my modem.  My PC and mobile device have connected to the wifi network (dd-wrt) however when i try to log into genie to manage the router it does not find it or allow me to log in???
confused......
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: Cannot connect to routers wifi
are you using a 3rd party firmware on the router?
DarrenM
Message 2 of 4
Hayezio
I bought it second hand. When i search for the wifi it shows dd-wrt so im quessing it does
Message 3 of 4
Did you factory reset? Any second hand modem is likely to have changes to things like passwords and SSIDs. Get it back to the defaults and start from scratch.
There is a manual for your device somewhere at the end of this link:
>>> D7000 | Product | Support | NETGEAR <<<
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 686 views
  • 0 kudos
  • 3 in conversation
Announcements
Orbi WiFi 7
