Orbi WiFi 7 RBE973
Reply
Connect a 4G LTE to a N750 WNDR4300 as a backup modem
Mike744
I would like to create a failover using a 4G LTE modem to my existing N750 WNDR4300 for DSL outages. I need an automatic switch over so if I am away on business, and the DSL drops, my IP modules would still function.  I have a 16 port netgear router attached to the 4300 and everything is on a UPS. Any ideas?
Message 1 of 5
Nodism1125
NETGEAR Expert
Re: Connect a 4G LTE to a N750 WNDR4300 as a backup modem
Hi Mike744,
WNDR4300 does not support WAN failover since it has single WAN port.
Message 2 of 5
Mike744
Thanks for the reply. Sorry if I did not phrase my question very well. I knew the 4300 supports only one WAN so I would like to know if Netgear still has a dual WAN router or something I can use to create a failover with the two modems. I know they were discontinued at least a year ago. I have found other dual WAN VPM routers but I wanted to stay with netgear.
Message 3 of 5
Nodism1125
NETGEAR Expert
We have ProSAFE FVS336Gv3 but the unit is already EoL.
https://www.netgear.com/support/product/FVS336Gv3.aspx
Message 4 of 5
Mike744
Thanks, I saw that one. Too bad it is EOL. Thanks you for the information.
Message 5 of 5
Top Contributors
Discussion stats
  • 4 replies
  • 1427 views
  • 1 kudo
  • 2 in conversation
Announcements
Orbi WiFi 7
