Orbi WiFi 7 RBE973
Reply
Connecting VEGN2610-1FXAUS to a different ISP
brad2020
Hi Netgear Community.
I was wondering if I could get some guidelines on how to connect VEGN2610-1FXAUS - Foxtel Hub to a different ISP since i have changed my provider recently but i still want to use this amazing modem/router rather than the terrible one i have been provided with.
Any help is appreciated.
Brad
Message 1 of 11
DarrenM
Sr. NETGEAR Moderator
Re: Connecting VEGN2610-1FXAUS to a different ISP
Hello Brad2020
If your new ISP allows customer owned modems you should be able to log into the router and go through the setup again and put in the new credentials and it should work.
DarrenM
Message 2 of 11
brad2020
Hi Darren ,
My new ISP does allow for this. But my router does not allow any other isp addresses than the original to be put in. The extension for the address is locked as ....@foxtel.com.au where as my new isp is ...@bigpond.com.au.
Message 3 of 11
gmac05
I have the exact same question.
Message 4 of 11
DarrenM
Was this modem provided by foxtel? have you tried to factory reset the device to see if it will clear it?
DarrenM
Message 5 of 11
brad2020
Tried and tested and not working.
Is it possible that this router is locked to foxtel and that is why the firmware is coded to have @foxtel.com.au unremovable ??
If so what is the process of flashing it's firmware so the gateway resets ?
Message 6 of 11
DarrenM
Brad2020
yea with modems provided by the ISP they could have it locked down to just there service.
DarrenM
Message 7 of 11
brad2020
Well I figured as much. What is the process of flashing the firmware ?
Message 8 of 11
DarrenM
No way to flash the firmware as it all goes through the ISP for this specific moden unless you are able to find a 3rd party firmware which Netgear does not recommend using.
DarrenM
Message 9 of 11
brad2020
So netgear recommends me having to put this modem away because I can't use it ?
That is definitely not useful.
Message 10 of 11
VE6CGX
Master
Suggest you to hard reset both modem and router to erase all the trace of your previous ISP. Then seek guidance from your new ISP. They may need to download  f/w to connect(register) your stuff to their system. My ISP does not allow any other modem. Only one they supply and they track it by serial number.  Their system will never accept unknown modem. For an example when I get a modem replacement first thing I do when I connect it and power up, I have to call ISP asking for activation of new modem. Otherwise it won't do anything. You said
new ISP allows other modems. They should activate it. I don't think it is case of PnP.
Message 11 of 11
Top Contributors
Discussion stats
  • 10 replies
  • 7323 views
  • 0 kudos
  • 4 in conversation
Announcements
Orbi WiFi 7
