Orbi WiFi 7 RBE973
Reply
Connectivity
Eberhard
Follower
Connectivity
The precise model description is: AC1900 Nighthawk VDLS/ADSL Modem Router, Model: D7000
I have a "HomeServer e-trayz" from TrekStor Xtreamer, wired to LAN ports #2 with the ethernet cable, just as I had with my old router, yet, it is not being shown in the network. Cable works, green LED on the homeserver is on, but I can't find the unit on the network. If I use the old router (FlyNet by Roper) it works just fine. What do I need to do in order to be able to use the external server again? Firmware D7000: 1.0.1.44_1.01.1
thanks,
Eberhard.
Model: R6900|Nighthawk AC1900 Smart WiFi Router
Message 1 of 2
William10a
Master
Re: Connectivity
Did you change the ip dynamic address range to not the the server's static ip address ?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 2815 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
