Reply
D1500 - WIFI DHCP Problem
BassemElhanafi
I use a
D1500
Router Firmware Version
V1.0.0.28_1.0.1PE
Windows 10.1
My problem is with the DHCP after I used the Router as a bridge (Access Point)
The thing is that it has given the gateway of the main router (Thompson) to the cable-connected PC which is (192.168.1.254), so it automatically connected to the internet without any problems .
But when I tried to connect via wifi my netgear router gave his own IP Gateway address which is (192.168.1.1) So my wireless device failed to receive the internet service .
I want it to give automatic IP addresses to any newly connected wireless device , but to give the main router's Gateway IP like it did with the cable connected PC , not his own .
Images are attached for further investigation .
[img]https://a.imge.to/2019/07/26/dfjcF.th.png[/img]
Model: D1500|N300 WiFi DSL Modem Router-Essential Edition
Message 1 of 3
antinode
Guru
Re: D1500 - WIFI DHCP Problem
> (Access Point)
   How are you using it now?  Did you reset its settings after these
(not-well-described) changes?
> [...] it has given the gateway of the main router (Thompson) to the
> cable-connected PC which is (192.168.1.254), [...]
   You lost me.  "it"?  What is this "the main router (Thompson)", and
what, exactly, is connected to what, exactly?  Hint 1: Every cable has
two ends.  Hint 2: If a device has multiple Ethernet ports, then
"connected to device" is not enough detail.
> [...] But when I tried to connect via wifi [...]
   "connect" _what_ to _what_ "via wifi"?
Message 2 of 3
BassemElhanafi
I meant "it" referring to Netgear not thompson and i was talking about connecting my mobilephone to the Netgear Router Wireless network
, Which takes a long time to acqurie the ip and other times it doesn't connect at all .
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 416 views
  • 0 kudos
  • 2 in conversation
Announcements
