Orbi WiFi 7 RBE973
Reply
D6000 - Experiencing a hissing/buzzing sound
Pretty_Pixel
I purchased my D6000 wireless modem router this morning and set it up. All is well apart from a fairly quiet hissing/buzzing sound which can be heard when close to the router. The firmware is up to date and the noise is present when both, or one wireless band is active. I have also turned off wifi and the noise is still present. Is the noise normal behaviour, or should I exchange the router. Advice would be much appreciated, thank you.
Message 1 of 3
Accepted Solutions
DarrenM
Sr. NETGEAR Moderator
Re: D6000 - Experiencing a hissing/buzzing sound
Hello Pretty_Pixel
Yes you may want to exchange with it making these types of noises.
DarrenM
Message 2 of 3
All Replies
DarrenM
Hello Pretty_Pixel
DarrenM
Message 2 of 3
Pretty_Pixel
Hello - thank you for the reply. I will exchange the router. Thanks again 🙂
Message 3 of 3
Top Contributors
Discussion stats
  • 2 replies
  • 3706 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
