Orbi WiFi 7 RBE973
Reply
D6000 connection problems
MichaelAus01
Follower
Hello
I have a Netgear D6000.
Just lately I have been having connectivity issues with the modem/router.  I have to go into the netgear settings and it says 'no internet connection' and I have to reset it.  Why is this occuring?  What should the settings be?
Thanks in advance.
Model: WNR1000v3|Wireless Router
Message 1 of 2
Re: D6000 connection problems
@MichaelAus01 wrote:
Hello
Your "footer" says WNR1000v3, which, if you have the D6000, means you are not in the best place to ask ab out Modem Routers.
That's here:
DSL Modems & Routers - NETGEAR Communities
What version is the firmware on the D6000?
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 469 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
