- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D6200 wired ports issue
- Mark as New
- Bookmark
- Subscribe
- Permalink
Recently bought a D6200. Wireless 2.5/5G work flawlessly. However I cannot plug more than one computer into wired ports. I am using DHCP with DHCP IP reservations (14 IP's). If I use more than one wired port, the addtional port may work for a few seconds or minutes, then all wired ports stop working. If I remove all but one port, the original single port stops working. Does not matter which ports but only the number of ports I try.
Behavior with > 1 port connected is strange. Sometimes I can see the entire network from a PC but not login to router or see the internet.
If I remove all but one port, That port's PC connectivity returns to nornal.
I upgraded firmware to v*_20 when I received the unit.
Any ideas ?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6200 wired ports issue
Hello microapp
You may want to do a factory reset something could of happened when upgrading the firmware that may be causing this behavior in the modem.
DarrenM
