- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D6200
- Mark as New
- Bookmark
- Subscribe
- Permalink
D6200
Noob question.
Want to use the router as a access point. Have it plugged into existing modem and has got a ip address from the modem. Have selected AP point in the sdvanced wireless settings.
But when i disconnect it loses that ip address.
What am I missing?
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6200
Firmware version?
> Want to use the router as a access point. [...]
Ok. Why? Is there some actual problem which you are trying to
solve?
> [...] Have it plugged into existing modem [...]
What, exactly, is connected to what, exactly? (Hint: If a device has
multiple Ethernet ports, then "connected to device" is not enough
detail.) What, exactly, is "existing modem"? Is it really a "modem",
or is it a modem+router"?
> [...] and has got a ip address from the modem. [...]
Sounds as if your (unspecified) "the modem" is a modem+router. What,
exacty, was that "a ip address"?
> [...] Have selected AP point in the sdvanced wireless settings. [...]
And how did you answer the questions when you did that?
> [...] But when i disconnect it loses that ip address.
What are you disconnecting from what? Why? Did the management web
site display a picture showing how to connect things when in "AP mode"?
Did it suggest _dis_connecting anything?
> What am I missing?
A clear description of what you want to do, what you actually did,
and what happened when you did it?
A wireless access point is called that because it provides wireless
access at some point away from the router. It's not called "wireless"
because it doesn't need a wired connection to the router (because it
does need one).
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6200
I have a telstra nbn modem serving wirelessly.
I have built a office for my smLl business downstairs. In that office i have a couple laptops. And a laser printer that doesnt have wireless. I wish to connect that printer to a router to utilise the printer server capabilities of the router. This is where the d6200 comes in. I wish to connect it wirelessly to the telstra modem and plug in the usb plug of the laser printer to the d6200 and have it serve the network as a network printer.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6200
> Ok. The long version.
Longer, but not long enough.
> [...] And a laser printer that doesnt have wireless. [...]
Not a very detailed description of anything. Does this (unspecified)
"a laser printer" have an Ethernet port, or only a USB connection?
> [...] I wish to connect that printer to a router to utilise the
> printer server capabilities of the router. [...]
Whether that's possible may depend on the printer capabilities. Some
printers, for example, expect to be connected to a Windows system (which
does most of the rendering work). Such a printer won't work with a
simple print server.
Adapting a non-wireless device to a wireless network is a job for a
wireless bridge, not a WAP. Some Netgear routers can do that, and there
are probably many other, simpler such devices, but I don't see anything
in the D6200 User Manual which suggests that it has such an option/mode.
Visit http://netgear.com/support , put in your model number, and look
for Documentation. Get the User Manual. Look for "bridge". Repeat
for, say, the R7000. In whose User Manual, look for "Set Up the Router
in Bridge Mode".
If your (unspecified) "a laser printer" has only a USB connection,
and it's situated near a wireless laptop, then you might have more
success more easily if you connect the printer to a laptop, and let that
laptop act as a print server. (What's the OS on these "a couple
laptops"?)
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6200
I thought, at this point it appears incorrectly, that the d6200 set as an AP would serve my purpose.
All i had to do was set the settings on the d6200 to access the telstra modem wirelessly plug in the printer and away we go.
Shouldve known things are not always what they seem.
- Mark as New
- Bookmark
- Subscribe
- Permalink
Re: D6200
> The printer is a samsung scx-4623f it has a usb plug and a rj11 port.
As I read the "User's Guide" for these things, I'd expect to see an
Ethernet network port on an SCX-4623FN ("N" for "Network"?), but only
two RJ11 telephone ports (for fax use) on the other/lesser variants.
http://h10032.www1.hp.com/ctg/Manual/c05786777
Everything's complicated.
With no intrinsic network capability, the SCX-4623F would seem to
need some kind of print server to make this printer network-accessible.
It's possible that a D6200 (in AP mode) could handle that part of the
job, but it appears (to me) that, lacking a suitable bridge capability,
it couldn't also handle the wireless connection back to your main
router. Stacking a D6200 and some kind of wireless bridge might work,
too, but you might need to call in (the late) Rube Goldberg to get it
all configured.
A Web search for, say:
wireless print server
might find something useful. Netgear seems to have made a WGPS606 many
years ago. Newer/better gizmos of that sort may exist now. (But old
and cheap might still be useful.)
There's much to be said for running an Ethernet cable from the main
router to the dungeon. It could open up whole new vistas of
possibilities to explore. There are also Powerline gizmos to fake an
Ethernet connection over existing power wiring.
