Orbi WiFi 7 RBE973
Reply
D6220 no DSL or Internet light
jpilko
Follower
Have connected the router to power and the DSL cable is connected through the filter to the wall socket, however I’m getting no lights at all for DSL or Internet.
Have called Exetel and they’ve confirmed our unit is getting service, have no home phone to test the connection, and there’s only one phone socket in the unit. Would it be a faulty socket?
Using the net gear Genie comes up with no DSL connection detected error, and when I try to manually set up the connection, after I make a new password and set up security questions it just gets stuck loading and never loads the next screen.
It never asks me for an ISP username and password or anything, I can’t set up anything on the router.
Cheers for any help.
Message 1 of 2
Re: D6220 no DSL or Internet light
You have plugged the DSL into the correct port on the modem/router?
Am I right in thinking that Exetel is an NBN service in Oz?
If so, what sort of NBN?
What is an NBN network and is my NETGEAR DSL modem router compatible? | Answer | NETGEAR Support
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 906 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
