Orbi WiFi 7 RBE973
Reply
D6300 Remote Desktop Connection lost when minimizing RDP window
Peds1969
Follower
Hi
I work from home a lot connecting to my work PC using Remote Desktop Connection (RDP) and my customers servers using RDP.
Used to have a DGND3300v2 and had no problems.
Replaced with a D6300 and I get the problem where if I minimise the RDP connection and then come back to it a couple of minutes later it tells me the connection it lost and I have to wait 1 retry before it connects again.
This is consistent to any device I connect with RDP so it is not the destination device causing this problem.
Any suggestions anyone?
Thanks
PETE
Message 1 of 2
Dom77
Re: D6300 Remote Desktop Connection lost when minimizing RDP window
Hi Pete
Did you ever fix your issue, I have the same problem.
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 3160 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
