- Subscribe to RSS Feed
- Mark Topic as New
- Mark Topic as Read
- Bookmark
- Subscribe
- Printer Friendly Page
D6300 VPN timeout
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
D6300 VPN timeout
when trying to log on to my work network via VPN, I get timed out after 5 minutes.
I have noticed a couple of posts about this on the forum where solution like changing the idle timeout to 0 and updated the firmware have been suggested. However both those solutions do not appear to have solved the issue.
Has anyone experienced a similar timeout issue and managed to solve it and if so, how?
thanks in advance
Gary
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Re: D6300 VPN timeout
I have the same issue with the D6400, all firmware versions up to V1.0.0.44_1.0.44.
The issue appears to be with the UDP session timer on WLAN connections. Everything is fine on wired connection, problem only occurs on WLAN (2.4 & 5 GHz).
As previous discussion in this thread, WAN MTU is set to 1492; Max ping size with DF set = 1464. 1464 + 28 = 1492. 1492 + 8 byte PPP header = 1500 max (non-jumbo) MTU. The problem persists.
I personally think this is a problem in the firmware or setttings not available in the GUI. If there was a problem with WAN configuration then I'd expect the same behaviour on wired & wireless connections.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@jonallport You've tried all firmware versions and still it's only happening on wireless connection?
NETGEAR Community Team
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
This looks like it's been remported by others before:
https://community.netgear.com/t5/DSL-Modems-Routers/D6300-UDP-Timeout/m-p/1007162#M6183
But remains unresolved.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thanks All.
The MTU setting was 1492 already.
so changing idle time out to 0 doesnt work
MTU setting is already big enough so no luck there
loading latest firmware doesnt help either
I use Cisco as my VPN client but also tried Shrewsoft's VPN client - no luck
so at the moment the only way I can work for longer than 5 minutes is to use my Telstra mobile broadband dongle and keep paying for downloads while I have unlimited downloads with my TPG ADSL line.
Very frustrating. bought the Netgear product as it came highly recommended but not happy atm
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
@jonallport Are you also using Cisco VPN client?
Do you all have QoS enabled?
If not, can you try to enable QoS and setup the Uplink Bandwidth to 1Mbps.
Reconnect your VPN clients and see if it will help.
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
Thank you @ElaineM that seems to have improved it. Obviously with uplink QoS set to 1Mb it was throttling me back, but no drops. Have now set QoS to 100Mb (more than my available bandwidth) and so far 15 minutes of continuous traffic 🙂
In this instance it's a Palo Alto Networks GlobalProtect VPN but the same behaviour occured with Cisco IPSec client and OpenVPN when using UDP transport.
Thanks again
- Mark as New
- Bookmark
- Subscribe
- Permalink
- Email to a Friend
thanks all. after doing yet another google search, I found a thread on the whirlpool forum where someone had a similar problem while gaming and someone else had proposed a solution which was tried and it worked. I have since tried the same and it worked for me, I stay connected to my work network via my Cisco VPN client for 6 hours (which is a limit imposed by my work's network I believe).
This is what I did (if you are going to try this , please understand it is at your own risk as I don't know what these settings do and therefore what harm it might cause)
Under WAN setup :
1. tick 'disable Port scan and DOS protection'
2. Untick 'Disable IGMP Proxying'
3. Disable 'SIP ALG'
