Orbi WiFi 7 RBE973
Reply
D6300 settings for French Orange Fibre
darth2602
Hello
I'm French, My D6300 is set to work with standard ADSL,  tomorrow, i'll get  "Orange Fibre" ,what is the good settings for French Orange fibre ?
i see, i can run an autodetect wizard, do you know if the firewall settings are kept or all settings are deleted ?
In advance, thanks
note : sorry for my English, i'm French....
Message 1 of 4
DarrenM
Sr. NETGEAR Moderator
Re: D6300 settings for French Orange Fibre
Hello darth2602
The router setting should stay the same such as port forwarding and the wireless. SO you should be fine going threw the wizard again to set up the new connection.
DarrenM
Message 2 of 4
darth2602
hello
i lauched the setup wizard, but it'don't work...
message : "Problem Detecting the Internet Connection - IP Address" ???
Message 3 of 4
DarrenM
darth2602
Does Orange Fibre allow you to use your own modem ? I have seen that alot of these fibre connections suggest you use there modems.
DarrenM
Message 4 of 4
Top Contributors
Discussion stats
  • 3 replies
  • 3139 views
  • 0 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
