Orbi WiFi 7 RBE973
Reply
D7000 Nighthawk wont connect to vDSL ISP
Jay_C
Follower
Hi,
I'm trying to setup the D7000 I just purchased as a vDSL modem and router with the UK ISP TalkTalk. I wanted to replace the Huawei modem/router provided by them, however I can't configure the D7000 to connect to the vDSL. The 1st thing I did was a firmware upgrade to v1.0.1.44.
I used the D7000 against the same ISP on the same line for an ADSL2+ connection, but then upgraded my package with the ISP to vDSL.
The ISP seems to use IPoE, but I can only see PPPoE when I look at the D7000. It also has an MTU of 1500 but that seems out of range for the D7000 settings.
I'm hoping that you can help!
Model: D7000|Nighthawk AC1900 VDSL/ADSL Modem Router
Message 1 of 2
Accepted Solutions
Re: D7000 Nighthawk wont connect to vDSL ISP
Hello,
When you login, Basic View >Internet.
You see the options just after VLANID, it says "Does your internet connection require a Login"
Tick no, this sets it to IPoE, aka DHCP.
VLANID should be 101
Message 2 of 2
All Replies
Hello,
Message 2 of 2
Top Contributors
Discussion stats
  • 1 reply
  • 6388 views
  • 2 kudos
  • 2 in conversation
Announcements
Orbi WiFi 7
